Configure actions to use filters for flow-based mirroring.
  • The access control entry (ACE) exists.
If you use the mirror action, ensure that you specify the mirroring destination: MLTs or ports.
    enable
    configure terminal
  2. Configure actions for an ACE:
    filter acl ace action <1-2048> <1-2000> {permit|deny} monitor-dst-mlt <1–512>
    OR
    filter acl ace action <1-2048> <1-2000> {permit|deny} monitor-dst-ports {sub-port]][,...][slot/all][all]}
  3. Ensure the configuration is correct:
    show filter acl action [<1-2048>] [<1-2000>]
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#filter acl ace action 901 1 permit monitor-dst-mlt 5
The following table defines parameters for the filter acl ace action command.
Variable
Value
1-2048
Specifies the ACL ID from 1–2048
1-2000
Specifies the ACE ID from 1–2000.
Configures mirroring to a destination MLT group.
monitor-dst-ports {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Configures mirroring to a destination port or ports.
{permit|deny}
Configures the action mode for security ACEs. The default value is permit.
